Has anyone else’s Versa 2 button get jammed? My phone is just over the 1 year warranty by a few days. I took a break from wear my watch as it causes my wrist to peel and when I went to use it again today I noticed the button is jammed and will not work. Definitely disappointed as my last Fitbit had issues just after the 1 year warranty expired. 😒
Seems like this is quite a common issue. following the recent updates, as it was working fine before.
Its more likely to be a software issue but you can try cleaning around the button in case it is actually stuck.
Its probably best to inform Fitbit Support directly. They may be able to help you.
