11-14-2022 20:14
11-14-2022 20:14
Hello, for some reason the side button on my versa 2 has stopped working. I’ve taken a small toothpick and small safety pin and tried to see if any debris/dust is preventing the button from working but it made no difference. You can physically see the button going down as you press it, but the Fitbit will not respond accordingly. I debated on letting it run dead to see if it would reset, but you need the button to turn the device back on and I don’t want to take the chance of it never turning back on. Thank you in advance.
11-15-2022 07:14
11-15-2022 07:14
I have exactly the same problem, tried the solutions you mentioned to no avail, now my Versa 2 won’t even tell the time because the ‘back’ button won’t work, and I’ve only had it for 2 months!
Best Answer11-15-2022 09:14
11-15-2022 09:14
Same issue here, have also tried compressed air.
Best Answer11-15-2022 14:15
11-15-2022 14:15
Happened to me too, just stopped today. Now stuck on wallet. Can't do anything!
Best Answer11-15-2022 23:38
11-15-2022 23:38
That’s exactly where mine’s stuck, and I don’t even use Wallet!
Best Answer11-16-2022 10:38
11-16-2022 10:38
I did an online chat with Fitbit and they're going to replace it for me. It was really easy to get it sorted. Try contacting them, good luck.
Best Answer11-16-2022 11:53
11-16-2022 11:53
I guess yours is within the warranty window? Mine was not, so I was offered a discount code, but I don't think it will work in conjunction with the Black Friday sale.
Best Answer11-17-2022 00:33
11-17-2022 00:33
I’m waiting to hear back from my email to them. This Versa 2 was bought with a similar discount code to the one you mention, to replace a previous Versa that stopped working after 15 months!
Best Answer11-17-2022 00:36
11-17-2022 00:36
Thanks. I’ve used the email route but will ring if I don’t get a reply (or use the chat)
Best Answer11-17-2022 07:52
11-17-2022 07:52
Mine will luckily go back to the main screen after so long, but I can't use half of the functions anymore.
Best Answer12-05-2022 19:38
12-05-2022 19:38
Update, I decided to try another fitness tracker, the Galaxy watch. It is AWESOME! Zero regrets. While I liked my fitbit, I've had three in six years die on me. Time to move on.
Best Answer12-06-2022 19:48
12-06-2022 19:48
Mine too. Stuck on wallet and the side button won't work.
Best Answer12-07-2022 03:22
12-07-2022 03:22
That’s where mine had stuck. I emailed from the Contact page on the website and after a couple of email exchanges, they sent me a new watch (device only, no strap or charger). I’d only had mine for 2 months though so it was still under warranty. We’ll have to wait and see how this one goes 😳. Good luck with yours.
