10-21-2020 08:05 - edited 10-22-2020 07:52
Hello.
For a couple of weeks now my Versa 2 that I bought in October 2019, has been having issues with heart rate tracking. Mainly the green light that should be on, turns off by itself and doesn't come back until the watch is restarted. Sometimes that lasts for some hours but on bad days it will last for a few minutes before it needs to be restarted again. This makes the heart rate icon to either get stuck on a number or straight up not show anything, so workout tracking is useless.
I'm no Fitbit engineer but taking into account that a restart solves the issue, it seems to me this is a software problem.
Anyways I tried these "popular" solutions with no luck:
The version that shows on the watch is 35.71.6.19 not sure if that helps.
Honestly I'm starting to get fed up with this, without heart rate tracking, it makes no sense to track workouts.
Any ideas on how to proceed?.
Thanks.
10-24-2020 10:07 - edited 10-24-2020 10:07
Same problem. Fitbit support has been useless
10-26-2020 19:52
10-26-2020 19:52
I have the same issue. 😔
10-26-2020 20:39
10-26-2020 20:39
I have exactly the same issue. I bought my Versa 2 on December 2019 and the BPM stoped working completely around August 2020. I have also tried every mentioned solution with no results.
10-26-2020 20:52
10-26-2020 20:52
Mine also stopped working around August 2020 and was purchased as a birthday present in the Fall of 2019! So maybe it’s their way of forcing us to buy a new one 😂
Best Answer10-27-2020 07:02
10-27-2020 07:02
Glad to know I'm not the only one, hopefully someone from support says something.
Best Answer10-27-2020 08:05
10-27-2020 08:05
If you have Twitter, send a message to @FitBitSupport, this where I’m at with them so far:
Got it! It seems that your Versa 2's heart rate is enabled and the restart reflected. Since we haven't been able to get your device working as expected, we'd like to create a case on your behalf so that our Technical Support team can further assist you. In order to do this, we'll need the following:
1.) Your full name.
2.) Preferred email address to contact you through (if it's different from your Fitbit account email).
3.) Country of residence.
4.) Retailer's name.”
Best Answer10-27-2020 11:06
10-27-2020 11:06
@dlopezuyI'm experiencing the same thing. I was gifted the Versa 2 for Christmas last year. Oct 2 was my last Detailed Sleep Score and on the 5th was my last Basic Sleep Score. No HR at all. I have the same version as you (35.71.6.19). And like you, I...restarted several times, tracker on/off/on, manually re-synced, turned watch off/on, re-synced, watch off/on, changed watch face, re-synced....no change! No green light, no HR, no sleep score NOTHING!
I hope we hear back! Good luck!
Best Answer10-27-2020 11:56
10-27-2020 11:56
Speak with a Live Agent (text chat thing). They went through a bunch of troubleshooting steps with me, and essentially, they are sending me a out a new one. Yours might still be covered under warranty too.
Best Answer10-28-2020 10:01
10-28-2020 10:01
I started using my old Charge 2 again, as it is now, my Versa 2 is too unreliable.
