09-28-2019 14:53
09-28-2019 14:53
Versa 2 connecting with Android 10 stopped receiving text notifications after just one day.
I have tried all of the steps listed in every forum post I could get my hands on:
still nothing. Calls have continued to work fine, but not texts. Getting very frustrated by this.
09-29-2019 01:01
09-29-2019 01:01
Hi @emelton22 @Skylla What phones are you guys using? Are they on the Supported Devices List?
Try the suggestions in THIS Help Article on Notification Troubleshooting
Helen | Western Australia
09-28-2019 16:31
09-28-2019 16:31
I've got the original Versa and mine has started this as well. I removed my Versa from my account and did a factory reset. I get notifications from other apps but not the Messages app.
09-29-2019 01:01
09-29-2019 01:01
09-29-2019 06:08
09-29-2019 06:08
My text notifications stopped working as well. I think/hope it’s related to the iOS update I did on iPhone. Hoping Fitbit will get it fixed quickly
09-29-2019 07:13
09-29-2019 07:13
09-29-2019 18:55
09-29-2019 18:55
@Skylla It should work with that phone. If you tried all the troubleshoots from the help article I linked above and still not working Id suggest you contact Support
10-01-2019 12:42
10-01-2019 12:42
I have NEVER received any text messages. I have Galaxy S10+ and using the default Messages app. I have tried another forum without success, I hope you can help me Nelly. I contacted support and they said to use a different device...yeah right!!! Too lazy to trouble shoot. This device worked with the first versa.
If this is not resolved in the next few days I am returning the product.
10-01-2019 16:24
10-01-2019 16:24
Update: Not sure which step it was that fixed it, but I repeated all of the steps listed above for a second time and it started working again and has been working for 3 days now with no further issues (knocks on all of the wood).
Maybe it was the 2nd uninstall? Maybe it was one of the many, many reboots I did? Maybe they should add a simple "Clear Cache" option to their software which I believe to be the actual culprit?
Also, I am using a Pixel 3 (not XL) with Android 10.
12-07-2019 06:13
12-07-2019 06:13
I'm also having the same issue. I have a Versa2 running with a Pixel2 on Android10. The watch fails to receive messages from the standard messaging app regularly. Disconnecting and reconnecting Bluetooth restarting the watch, restarting the phone, verifying that every setting is optimized and permissions are set to allow messages - and still nothing keeps the connection consistent. I bought this watch for the text messaging connectivity and I'm pretty close to returning it due to the amount of frustrations I have had with it.
12-23-2019 13:03
12-23-2019 13:03
Same issue here. I have a Samsung Note 9, which is on the list.
Help please.
01-13-2020 20:56
01-13-2020 20:56
Is it still working... I just bought a new S10 plus and I've tried everything.
01-15-2020 09:16
01-15-2020 09:16
Mine started working for a few days then as well, but now I am no longer getting message notifications. Versa 2, Samsung S10e
01-22-2020 19:52
01-22-2020 19:52
I switched from a Galaxy S10e (messages worked & then didn't work after update) to a Galaxy Note 10 with updated Operating system Android 10. Text messages not working. Infuriating. My husband has same phone with a Versa and it works fine. My Versa 2, not so much.
01-30-2020 17:24
01-30-2020 17:24
I own the Samsung s10e and have the same issue. I have done everything including resets and uninstalls with no success. I'll try support and if not resolve I'll have no choice but to return it.
02-02-2020 17:03
02-02-2020 17:03
I'm in the same boat. I called support. They said they were aware and they thought the issue was the app and we had to wait for an update. That was a month ago!
02-02-2020 18:53
02-02-2020 18:53
I was having this issue with a Samsung S10 using the native messaging app. Getting all. nofications except texts. I downloaded and started using Google Messages as my default messaging app and it now works. Saw this in another thread about this issue also saw on there that Messages+ also worked for people. Hope this helps you all!
02-02-2020 19:01
02-02-2020 19:01
Thanks that totally worked downloading google message .
02-03-2020 08:56
02-03-2020 08:56
Thanks! Google messaging app worked. I'm still going to hound Fitbit support until they fix the issue, but at least I'm getting text notifications again. 😁😄😀
08-29-2020 21:07
08-29-2020 21:07
I cannot believe I just changed from IPhone to Android to not have the same compabilities I had. I purchased the Samsung Galaxy A71 and the Fitbit Versa 2 to only find that they are not compatible for texting and emails. I understand your resources have changed with the Pandemic but it is very disappointing to not have these resources but also to have spent hours trying to find a fix. Please share with me and your other customers that there is a legitimate fix now. Thank you.
01-07-2021 10:50
01-07-2021 10:50
Your post was nearly a year ago. I have a Galaxy S10 and not working. You ever hear anything?
