08-26-2023
19:31
10:46
08-26-2023
19:31
10:46
when I plug it in, nothing, when I plug it into the computer, I get some sounds, connecting sounds? I have tried pressing the button for many seconds, nothing. is there anything I can do? thanks.
08-27-2023 10:47
08-27-2023 10:47
Hi there, @entooit. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer08-27-2023 16:20
08-27-2023 16:20
Hi Marre,
This won't work if your fitbit is blank and the fitbit logo is coming up every 10 seconds. Once the fitbit device is removed from the bluetooth there i no way you can connect it again. The device won't start up anymore. It is charging though but doesn't turn on anymore. Only the flickering fitbit logo. Is there a huge softare error going on here that affects all the versa 2 and 3 users?
Best Answer08-27-2023 21:17
08-27-2023 21:17
This versa in new tome it has never been paired with my phone, that I can tell. So I cant unpair it either, right? I cant set up the fit bit on the device, and I cant set it up on my phone app, because I think it is not connected via bluetooth. restarting does not work either. holding the button for ten seconds, right? when I plug the fitbit into the computer I get a connecting and disconnecting sound, one after the other. is there some kind of hard reset?
