03-16-2024
19:41
08:05
03-16-2024
19:41
08:05
It says it has a 50% charge. Stays black when put on charger. Stopped recording any information after 2 pm today. What is problem. What do I do?
03-17-2024 07:06
03-17-2024 07:06
03-16-2024 22:19
03-16-2024 22:19
Hi @Karen1955 - due to syncing issues, check in the Fitbit App when the watch last synced and was at 50%.
This will tell you if it suddenly died (possibly after getting wet) or has just run down over time.
If the latter try charging from a PC port, and ensure watch and charger terminals are clean, and that is your usual charger.
If it's no longer operational and is under warranty it can be replaced.
03-17-2024 07:06
03-17-2024 07:06
03-17-2024 08:07
03-17-2024 08:07
Hi there, @Karen1955. Welcome to the Fitbit Community Forums. I'm pleased to hear that you managed to solve the issue with your Versa 2. Thanks for sharing the steps that worked for you. @Guy_ I appreciate your help!
In case you have some spare time, I would like to invite you to visit our Health & Welleness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! 😊
03-17-2024 15:10
03-17-2024 15:10
The exact same thing happened to mine yesterday! I'm going to try your suggestion! Thanks for sharing it.
03-17-2024 15:17
03-17-2024 15:17
Can I ask if yours made the buzzing or vibration sound every now and then when you put it on charge? And did it get very very hot? The screen that is. I've got no lights showing but occasional buzz and screen is super hot. A bit concerned 😟
03-17-2024 19:57
03-17-2024 19:57
Hi @Beck_Slev - if the watch gets hot when charging (or at any time) stop immediately.
If it's under warranty still get it replaced as it has an unrecoverable fault (possibly from water).
03-17-2024 21:14
03-17-2024 21:14
Ok thanks. I appreciate your reply.
You said possibly from water... so they aren't waterproof for swimming despite them saying they are? I've been wearing it swimming most days for the past 3 weeks as it says waterproof for swimming but not good in showers due to soap etc.... I dare say it's water then 😄
