So just got the new Versa 2 and the cable attached to the charging cradle comes out the bottom, so I cannot rest it in my desk facing up, it has to be in on its side. Is this by default, very annoying
any thiyghts
thanks
I have both the Versa and Versa 2 and I can confirm that the Versa charging cable is not compatible with the Versa 2 and vice versa (I have tried).
My Versa 2 charging cable also has the cable out the bottom, not the side, which I though was odd, too.
Hi, no this is not normal. The cable should come out of the back of the cradle. Contact Customer Support and ask for a new cradle. You should be liable to get a new one ASAP since it's a new one. Regards kuzibri.
My V2 cable comes out of the back of the cradle as well. I believe that is the way Fitbit designed them. You can find inexpensive cradles with cables out the side on Amazon. One such is:
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Hi, can't you use the cradle from the Versa? If I look at the images on the site it looks the same, so it's worth to give it a try. Regards kuzibri
BTW, when the cable comes form the bottom, is there no hole on the back of the cradle to lead the cable through??
@JohnPacheco The advice offered by @SunsetRunner will not help you. There is no reason to contact Support. You received the correct charging cable. The Versa charging cable will not work. The Versa 2 is thicker and does not fit.
Thank-you @wtksk8r for finding a third party charger for those who want the device to lie flat while charging.
Laurie | Maryland
Hi, thanks for the information. Good to know before switching to the Versa 2 when it becomes available in my country. Regards kuzibri.
Apparently they designed the charger that way. I don't know what industrial designer came up with that, but it's sub-optimal and bad design. Having said that it looks like a decent upgrade. I'll be buying a replacement charger that is more practical.
The Versa Lite charger was also the same sort of design, I found it odd as soon as I saw it. Luckily with the Lite you could still use the much better designed original Versa charger.
Best AnswerEveryone, thanks to all of you who replied, glad I am not the only who thinks this design is flawed. Also it's not right that we have to purchase a secondary charger to allow the V2 to charge flat. I mean i would be okay with the design if it definitely showed that you could lie it on the side, or at least, since it's plugged in and you are not using the "Always On" feature, to turn it on like a clock. Hopefully Fitbit is looking at this thread and could comment on the reason for this design decision.
Be well
I spent 5 minutes with the charger that came with my new Versa 2 and went straight to Amazon to buy one that is not stupid. I wondered if they wanted to sell a doc that the charger clips onto but I don't see one in the store. So Amazon it is.
@SunsetRunner Your link goes to a Versa charging cable, not for the Versa 2.
Best AnswerFirst not sure who was the genius coming with that type of charger for versa 2 and other bunch of geniuses who approved this annoying design. I was fiddling with charger thinking some part must be missing but then found online that many people suffering from same issue. To make things worse, also not working with early versa charger. Ideally fitbit should replace all these charges with better one
Is the cable longer on the one you bought? Silly we should gave to spend more $$$ for practicality.
Best AnswerI too switched from the Versa to the Versa 2. The charging cradle is a piss poor design. Why would anyone want to charge their Versa 2 on its side? Someone dropped the ball big time on this one. I may have to buy an off market charging cradle. I am about to jump ship with Fitbit. I thought the Versa 2 would be an upgrade but I was mistaken. Poor design on charging cradle & I am still having syncing issues with this new & improved design.
I have Fitbit versa 2 it does come out the bottom. The person who said no it is not normal that it comes through the side is INCERECT. Fitbit versa 1 comes from the side. Fitbit versa 2 comes from the back side.
Best AnswerThat website is for Fitbit versa 1 not 2
