09-16-2019 15:20
09-16-2019 15:20
I'd like to use the interval timer but it's currently locked to only one type.
Move 30 seconds and rest 10 seconds. Repeat 14 times.
I'd like to do 2 minutes move and 2 minutes rest. Is it possible?
02-17-2020 03:10 - edited 04-28-2020 05:27
@FikT The settings for the Interval Timer are in the app. It is in the same place for every device that has an Exercise app. Tap on you profile picture > your device > Exercise Shortcuts > Interval Workout. Set your move/rest/repeat there.
Laurie | Maryland
09-19-2019 18:36
09-19-2019 18:36
Welcome to the Fitbit Community, @Uno99. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing your concern about changing the interval timer. It is possible to set custom intervals and you can find the steps to do it in this help article: How do I set or change interval lengths in the Exercise app?
Best of luck with your health and wellness goals! I'll be around if you need further help.
12-13-2019 16:16
12-13-2019 16:16
I can't believe how impossible it is to find answers about using a Fitbit. I want to change the interval timer as well, found this answer, and the link goes to a page that does not discuss the interval timer. Can anyone answer the question of how to change the intervals on the interval timer?
12-15-2019 05:05
12-15-2019 05:05
Your link was useless. It didn't help the question at all.
12-20-2019 08:13
12-20-2019 08:13
Following the link provided there are steps to update the information provided by the interval app; however, it does not discuss anywhere how to change the default move time, rest time or repeat. Using the hamburger menu you can see what these are set to, but not adjust them. The gear in the top right only lets you adjust the stats, connect to GPS or set always-on.
01-06-2020 14:45
01-06-2020 14:45
I agree. You could do this on the charge. Pay more, get less?
01-16-2020 18:11 - edited 01-16-2020 18:22
It is under exercise shortcuts, after you click on your device. Click on intervals and it will let you adjust.
02-04-2020 11:59
02-04-2020 11:59
That doesn’t work. When you sync it defaults to the presets on the watch. Not the app.
02-04-2020 12:02
02-04-2020 12:02
Ok it worked after 4 or 5 times trying to sync
02-17-2020 00:18
02-17-2020 00:18
Just worked for me thank you.
02-17-2020 01:59
02-17-2020 01:59
Is this for versa 2 or charge?
Laurie | Maryland
02-17-2020 19:06
02-17-2020 19:06
04-22-2020 06:14
04-22-2020 06:14
I’m still happy with my Fitbit and it has nice features etc.
but this isn’t the first watch you have produced and with a lot off options it seems like you have learned nothing on making things work properly...
and the reason I send this negative message is that with every issue I (and many people like me) have, the response of Fitbit is a bull**ahem** link to something that doesn’t explain it or You handle bugs that are mistakes in the watch as if they are a good ideas to maybe look into in the future and encourage people to keep reporting “these ideas” ....
your service, responses and answers are extremely bad, you should solve issues and stop with the bull**ahem** responses, you annoy me and I feel you waist people’s time
(like this issue in this post, setting the intervals is challenging and needs multiple attempts to sinc properly... this is not a good idea, it’s a bug that needs fixing.... the watch paired to Bluetooth earphones usually doesn’t allow to change the volume on them and the basic setting is eat damaging loud, so not usable... this is a also a bug and Needs fixing.... I chose Fitbit over Apple Watch because of the less expensive price and the fact that Apple only wants To connect to there own products, is this going to be the same strategy on earphones for Fitbit?
so in short; please improve your services
04-28-2020 06:12
04-28-2020 06:12
That worked thanks 🙂
09-05-2020 07:41
09-05-2020 07:41
I want to setup interval exercises on my Versa2. How to proceed.
09-23-2020 15:33
09-23-2020 15:33
09-24-2020 11:44
09-24-2020 11:44
Broken here, as well. See configuration in signature block.
09-24-2020 14:02
09-24-2020 14:02
I find that I have to change each interval (say it was set at 2 and 2 and I want 4 and 2, I still reset all intervals). Then you have to resync, sometimes more than once. It's an annoying glitch.
09-24-2020 16:05
09-24-2020 16:05
I went ahead and changed both values as @Lubison suggested - immediate communication to my device and the settings were reflected. No explicit sync required.
Just in case, I forced a sync three times and the setting remained on the device and are still reflected in the app.
Just another inconsistency that we have to work around, folks.
