Versa 2 not charging
ANSWERED
I used my fit bit last week no problems with anything
it’s completely flat
I decided to use it again this week and put it on charge and nothing is happening
no light saying it’s charging left it for a few hours in charge and still nothing
any ideas
1 BEST ANSWER
Accepted Solutions
Welcome to the Community, @SunsetRunner.
Thanks for the details provided about the charging difficulty. I recommend you to check this help article and try the troubleshooting steps listed there to charge your Versa 2.
Hope this helps.
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
2 REPLIES 2
Hope this helps.
Thank you so much I restarted it by holding the side button down for 10s and it’s turned on and charging thank you
