09-12-2019
20:37
07:01
LizzyFitbit
09-12-2019
20:37
07:01
LizzyFitbit
I have a Versa 2 and an iPhone X and cannot seem to get my text messages to my watch. All the settings are on to receive notifications on phone & watch. I had no issue with this and the blaze. Help please:)
09-13-2019 07:14
09-13-2019 07:14
Hi @hbkRN. Welcome to the Community Forums.
It's great that you got our newest Versa 2, congrats! Thanks for making sure of the notifications settings and let's work on this together. May I know if you're able to receive other types of notifications, such as calls, calendar, or apps? If so, please make sure the Do Not Disturb settings are off in your phone and Versa 2. Also, go to your phone's settings, tap on Notifications > Text messages and enable the three options under alerts.
Since you mentioned to have had a Blaze before, I'd recommend the following steps:
Let me know the outcome!
09-13-2019 07:14
09-13-2019 07:14
09-26-2019 08:28
09-26-2019 08:28
My Versa 2 receives all notifications except text messages. I have done all trouble shooting (settings on phone- settings on fitbit) and it is not resolving the problem. EXTREMELY disappointed to have spent this much money and this much time trying to resolve this problem. I have tried all fitbit community posts to resolve the issue- any help would be greatly appreciated.
09-26-2019 15:39
09-26-2019 15:39
@seh1981 Phone model and OS? If it's Samsung you need to enable Preview Messages in your phone Settings.
09-27-2019 06:05
09-27-2019 06:05
I have an iphone 7+.
09-29-2019 06:22
09-29-2019 06:22
My texts WERE working and then I did an iOS update and they no longer do. Hoping that is the problem and Fitbit will resolve it.
09-29-2019 11:39
09-29-2019 11:39
iOS13 has changed bluetooth settings. This will have to be addressed witht he fitbit mobile app update. For now try this:
09-30-2019 06:51
09-30-2019 06:51
I have never received text messages on my versa from my samsung Galaxy S10+. I checked and my preview text messages is on. I turned it off and back on, I have also uninstalled and reinstalled my fitbit app on my phone. I am ready to return this if I can't get this resolved.
09-30-2019 14:39
09-30-2019 14:39
@Mamamurt which messasging app are you using? Have you tried uninstalling and reinstalling fitbit app to prompt the notification permission request?
09-30-2019 19:56
09-30-2019 19:56
10-02-2019 12:12
10-02-2019 12:12
@Mamamurt Are all notifications enabled for Versa in the fitbit mobile app? Can you try downloading Google Messages from the play store and setting it up as your default texting app, then enabling notfications for it in the Fitbit mobile app?
10-03-2019 10:37
10-03-2019 10:37
I am having the same issues. Vibrations are working, tested with an alarm, but not receiving notifications for texts. I removed the Bluetooth device as you suggested and re-paired but that did not resolve my issue.
Any other suggestions?
10-03-2019 15:30 - edited 10-03-2019 15:31
I am also having the dame issue. I can get phone calls, calendar reminders, other app notifications but no text messages. Is this an watch defect issue? I did all the other suggestion noted and nothing worked.
10-07-2019 12:24
10-07-2019 12:24
Hi
Just has the same problem with an iPhone X and versa 2.
Resolved the problem by going to notifications, messages, scroll to the bottom select show previews. Make sure your phone is set to when unlocked or always.
Make sure it’s not on never.
Notifications should then start coming through.
Hope this helps!
10-07-2019 12:48
10-07-2019 12:48
10-07-2019 17:43
10-07-2019 17:43
I’m having the same problem. Super annoying.
10-07-2019 17:51
10-07-2019 17:51
10-10-2019 07:56
10-10-2019 07:56
I am having the same issue too. I have deleted the versa from my Bluetooth paired devices and repaired it, I have reset the fitbit, turned my phone off and on, ensured text message notifications are enabled within the fitbit app, and ensured they are enabled within my phone's settings. Nothing seems to help. I assume it is just a glitch with the first "batch" of versa 2s that were released because it seems to be happening to others. I will occasionally receive a text on my versa 2, but nine times out of ten it doesn't come through.
10-10-2019 08:00
10-10-2019 08:00
10-19-2019 08:44
10-19-2019 08:44
I am having the same problem as well, I have a Vera 2 and iPhone X and I receive all notification except for texts, which is the notification I would like to be receiving. I’ve done all the troubleshooting, turned both devices on and back on. All updates are made. I tried on different days. Nothing is working. Any new updates/advice on this issue since the 10/10/19 troubleshooting article?
