10-26-2024 04:44
10-26-2024 04:44
My versa 2 has stopped syncing with my Samsung A13 since an update to Android 14. I have deleted and reinstalled the app, done the bluebtooth turn off and back on & also done a factory reset on the fibut but it still won't connect via Bluetooth to the app. Any ideas?
11-03-2024 00:33
11-03-2024 00:33
Followed all the above steps and still no luck with mine, I have been unable to sync my phone and Versa 2 since Wednesday 23rd October, I have deleted everything and re - installed everything many times over the last 11 days without any luck at all; The error messages i get are "Something went wrong, please try again", "An app is needed to use this device", when trying bluetooth and "Incorrect code" when trying to enter the 4 digit code you send me. Honestly 11 days is ridiculous to sort this "bug" out, surely there's got to be a way of testing them first? Please get it sorted asap!
Best Answer11-11-2024 12:38
11-11-2024 12:38
I had the same problem, then the latest app update seem to fix until today when it's gone again. Gone through all the usual steps and it's still not working.
Best Answer11-11-2024 13:36
11-11-2024 13:36
Updated to latest App 3 weeks ago, deleted, reloaded, cleared cache, cleared bluetooth many times....and absolutely nothing
Apart from they collected my monthy fee today.
Totally brassed off with it
Best Answer11-11-2024 14:37
11-11-2024 14:37
Best Answer11-12-2024 05:57
11-12-2024 05:57
Hi there everyone!
Thank you for your responses and all your efforts.
Can you please all check if your devices have a pending firmware update and if you can update the Fitbit app too?
You can try this troubleshooting too:
