My versa 2 has stopped syncing with my Samsung A13 since an update to Android 14. I have deleted and reinstalled the app, done the bluebtooth turn off and back on & also done a factory reset on the fibut but it still won't connect via Bluetooth to the app. Any ideas?
Followed all the above steps and still no luck with mine, I have been unable to sync my phone and Versa 2 since Wednesday 23rd October, I have deleted everything and re - installed everything many times over the last 11 days without any luck at all; The error messages i get are "Something went wrong, please try again", "An app is needed to use this device", when trying bluetooth and "Incorrect code" when trying to enter the 4 digit code you send me. Honestly 11 days is ridiculous to sort this "bug" out, surely there's got to be a way of testing them first? Please get it sorted asap!
Best AnswerI had the same problem, then the latest app update seem to fix until today when it's gone again. Gone through all the usual steps and it's still not working.
Hi there everyone!
Thank you for your responses and all your efforts.
Can you please all check if your devices have a pending firmware update and if you can update the Fitbit app too?
You can try this troubleshooting too:
