10-06-2019 11:20
10-06-2019 11:20
As the title says, it's only showing 7 excersizes total under the excersize shortcuts menus, when it's supposed to show 15 and I pick 7 to see on the watch . I can't start anything like an elliptical workout or stationary bike which is what I do the most of.
10-06-2019 17:23
10-06-2019 17:23
"All shortcuts in use. ... Swipe left on any shortcut to remove."
You already have the max 7 selected. You have to remove one or more to see the other options.
10-06-2019 12:54
10-06-2019 12:54
As explained below, those choices are all shown in the app settings; you choose from there which ones to show on your tracker.
How do I change or reorder the exercises in the Exercise app?
Choose from over 15 exercise types—including run, interval workout, swim, and yoga—to customize the app with your favorite workouts. If a specific exercise isn’t available, choose workout as your exercise type.
10-06-2019 16:33
10-06-2019 16:33
And as I stated in my original post it only has 7 options to add. None extra, it does not show the other 8 to put in the shortcut slot. If I can figure out how to upload a pic I will
10-06-2019 16:39
10-06-2019 16:39
the screenshot of my excersize shortcut screen
10-06-2019 17:23
10-06-2019 17:23
10-06-2019 17:42
10-06-2019 17:42
Wow was I having a brain fart 😂 that was itit than alot !!
10-06-2019 18:25
10-06-2019 18:25
No worries. It's not explained well. Many have the same issue at first.
By the way, if you want to post pic/screen shot here, you can use the camera icon just above the text box.
