l have the Versa 2 and the Quick Settings when you slide down from top is ridiculously annoying. I just want to see my notifications and battery percentage sometimes. But it blocks the view for seconds each time. I can't seem to disable this.... If it's not possible to disable this, we should at least be able to choose what's listed in the drop down quick settings menu. I will NEVER use the music or wallet apps......
You're not the only one that would like this changed. There is a feature suggestion for it and if you'd like to add your vote you can find it at https://community.fitbit.com/t5/Feature-Suggestions/Turn-off-edit-quot-Quick-Setting-quot-notificati...
Note, though, Fitbit's comment that they don't have any current plans to make the change. Perhaps with more votes they may change their mind.
Best AnswerQuite right, it is stupid!
The problem is that Fitbit are calling the community request to change this a "feature request", when in fact it is a bug fix or defect. If you changed something in your firmware (user interface in this case) which makes the device not work correctly or difficult to use, it's a defect not a feature.
Unfortunately, Fitbit clearly think adding multiple clock faces is more important than keeping current and future customers happy. [/Sarcasm off]
Personally, after waiting over a year for the fabled SPO2 sensor amongst other things, now this, I'm done with Fitbit. I wonder how many other loyal customers they have or will lose? My spending will now go elsewhere.
Goodbye!
