02-25-2020 01:44
02-25-2020 01:44
l have the Versa 2 and the Quick Settings when you slide down from top is ridiculously annoying. I just want to see my notifications and battery percentage sometimes. But it blocks the view for seconds each time. I can't seem to disable this.... If it's not possible to disable this, we should at least be able to choose what's listed in the drop down quick settings menu. I will NEVER use the music or wallet apps......
02-25-2020 01:48
02-25-2020 01:48
You're not the only one that would like this changed. There is a feature suggestion for it and if you'd like to add your vote you can find it at https://community.fitbit.com/t5/Feature-Suggestions/Turn-off-edit-quot-Quick-Setting-quot-notificati...
Note, though, Fitbit's comment that they don't have any current plans to make the change. Perhaps with more votes they may change their mind.
02-25-2020 01:48
02-25-2020 01:48
02-25-2020 01:51
02-25-2020 01:51
Thanks man!
02-25-2020 01:54
02-25-2020 01:54
This is the dumbest "feature" ever. It looks like theyve disabled comments on that feature suggestion? I've clicked to vote but can't comment. Stupid
03-08-2020 11:21
03-08-2020 11:21
Quite right, it is stupid!
The problem is that Fitbit are calling the community request to change this a "feature request", when in fact it is a bug fix or defect. If you changed something in your firmware (user interface in this case) which makes the device not work correctly or difficult to use, it's a defect not a feature.
Unfortunately, Fitbit clearly think adding multiple clock faces is more important than keeping current and future customers happy. [/Sarcasm off]
Personally, after waiting over a year for the fabled SPO2 sensor amongst other things, now this, I'm done with Fitbit. I wonder how many other loyal customers they have or will lose? My spending will now go elsewhere.
Goodbye!
