09-27-2019 05:47
09-27-2019 05:47
Hello I just received my fitbit versa 2 and my phone is rejecting the pairing. I have a samsung galaxy J7 sky pro. I checked for an update on my phone. I have the latest fitbit app. If it doesnt work with my phone then i need to send it back asap. thanks
09-27-2019 07:11
09-27-2019 07:11
Hi, have a look on these two sites:
1. https://help.fitbit.com/articles/en_US/Help_article/2315
2. https://www.fitbit.com/devices
On neither of these sites your phone is in the supported list, yet. This can cause these problems. Also have a look on this site: https://help.fitbit.com/articles/en_US/Help_article/1873/?q=pairing&l=en_US&fs=Search&pn=1 and see if it contains helpful information for you to overcome this problem. If nothing works, either you can wait for your phone to be supported (not listed does not always mean not supported, but not being tested at this moment) or, indeed, send it back. Regards kuzibri
09-27-2019 07:25
09-27-2019 07:25
Hi @Bridget1586, If the links that kuzibri posted do not help, I would suggest contacting Fitbit support before deciding to return the device. I had the same issue with the original Versa and my LG ThinqG7. It was not on the supported devices list but Fitbit support was able to help me get them paired.
09-27-2019 07:49 - last edited on 09-27-2019 13:45 by LiliyaFitbit
And yours worked completely fine? All functions? I contacted fitbit and they said there are options but can't guarantee all functions will work
09-27-2019 08:10
09-27-2019 08:10
@Bridget1586 Yes, all functions worked fine. I got the original Versa the day it came out and used it the whole time with the LG ThinqG7 (about a year and a half). You could have them help you set it up and if the functions don't all work, then you could return it.
09-27-2019 08:31 - last edited on 09-27-2019 13:45 by LiliyaFitbit
Thank you for your help!
09-27-2019 09:16
09-27-2019 09:16
@Savoir which Fitbit do you have? Just so you know, this is NOT a dating site and members come here for help with their Fitbit and not to make connections.
09-27-2019 09:33
09-27-2019 09:33
@Bridget1586 you might want to edit your posts to remove your name from them. Since this is a public forum, anyone can see that. To edit go to the upper right of your post and tap on the three lines. Select edit and then edit your name out. Post as usual. Then do that to the other posts in this thread where your name appears. It's just safer that way.
09-27-2019 09:38 - last edited on 09-27-2019 13:46 by LiliyaFitbit
Hahaha thanks!
09-27-2019 09:44
09-27-2019 09:44
I dont see the option to edit.
09-27-2019 09:45
09-27-2019 09:45
ok @Bridget1586 I'll let a moderator know so they can edit it for you.
12-20-2019 00:11
12-20-2019 00:11
Versa 2 does not find it
12-20-2019 11:32
12-20-2019 11:32
I have a Samsung Galaxy J7 Skypro smart phone. I have been unable to get my fitbit versa 2 to pair with it. What are my options?
12-25-2019 08:23
12-25-2019 08:23
Did you call Fitbit support and are they able to help you connect you phone to it? I have the same issue and want to be sure before anything
12-25-2019 09:23
12-25-2019 09:23
12-25-2019 12:11
12-25-2019 12:11
@Bridget1586 did you end up calling Fitbit support? And if so did they help you to connect your phone, I'm running into the same problem
12-25-2019 12:14
12-25-2019 12:14
@Lemma did you call Fitbit support and did they help you connect your phone? I can't connect mine because phone is not on the list
01-07-2020 13:53
01-07-2020 13:53
I'm not able to get mine paired or get notifications. I did a factory reset because nothing was working, but it still isn't working.
01-08-2020 14:49
01-08-2020 14:49
I tried calling and it still won't connect via Bluetooth, they said this can continue to be a problem if your phone isn't on the support list. Some of the functions work now but not all
01-08-2020 14:57
01-08-2020 14:57
FITBIT VERSA LITE WILL NOT PAIR WITH MY IPHONE 5S
