11-07-2022
11:19
11:39
11-07-2022
11:19
11:39
Screen looks dead to me. No amount of restarting, changing clockface, etc. fixes it. Can't factory reset as the screen is not visible although you can see a faint outline of the clockface numbers. Syncs fine to app and can feel vibration notifications though. I assume this screen is dead and is not repairable? It was charging overnight and just woke up to this. This is only 2 years old, so if the screen is dead after 2 years...what a waste of money.
11-07-2022 11:41 - edited 03-26-2024 12:21
Hi there, @mikeduffy13. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out and the image attached showing how it looks like.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
I've moved your post to the Other Versa Smartwatches board for organization purposes.
11-07-2022 13:23
11-07-2022 13:23
I'm having the same screen trouble, and mine won't even sync. Mine is less than 2 years old.
This is my second Versa 2, and I'm getting really frustrated. 🙁
11-07-2022 14:45 - edited 03-15-2024 11:51
Hi there, @jbvirginia. Welcome on board. Thanks for the details you shared about the issue with your Fitbit device. I understand why you're getting frustrated.
If you haven't done so yet, I suggest restarting your Fitbit device as suggested here.
11-08-2022 04:34
11-08-2022 04:34
Definitely go through to customer services, I have just got a replacement - fingers crossed!
11-08-2022 06:32
11-08-2022 06:32
No luck restarting. ☹️
11-15-2022 14:19
11-15-2022 14:19
I replied back to the email I received but have not heard back on next steps at all.
11-15-2022 20:37
11-15-2022 20:37
Exactly what I'm going through. Tried all the same things. I just got a new versa a few months ago because this happened with my prior watch. Beyond frustrated because of the money spent.
