Versa 2 screen corrupted
My versa 2 screen is glitching, flashing with lines like a broken TV screen.
3 REPLIES 3
Welcome to the Fitbit community, @Wren30!
Sad to hear that you're having an issue with your Versa 2.
If you haven't tried that already, I'd suggest restarting your device to see if that will get things fixed.To do so, please hold your Versa 2's button for around 10 seconds until you'll hopefully see the Fitbit logo on it's display. Then release the button to let your device restart.
If that won't work for you, please try changing it's clock face to get it back to working order. Here's how to do that:
How do I change the clock face on my Fitbit device?
Finally, you could also try to get your devices battery drained to the point when it will shut off. Then give it a full charge and see if it is working as it should.
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Thank you for your reply. I went on tech support and they advised the same.
It's working ok at the minute. Not sure if the clock face I had before was
too high resolution.
Hi there, @Wren30. Welcome to the Fitbit Community Forums. I'm glad to hear that our Support Team was able to help you solve this issue. @Talahthas Thank yo so much for your help and advice!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
