08-31-2020
14:12
22:16
RicardoFitbit
08-31-2020
14:12
22:16
RicardoFitbit
Fitbit versa 2 device screen not swiping.
Tried to hold the button for reset with no success. It goes to ''Alexa" then back to home screen. Won't swipe to see features or messages.
Moderator Edit: Content
09-02-2020 22:10
09-02-2020 22:10
Hi @Belinda44, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. If you haven't already done so, please try changing the clock face of your Versa 2 and follow the next steps:
I'll be here if further assistance is needed.
09-02-2020 22:10
09-02-2020 22:10
09-03-2020 01:27
09-03-2020 01:27
09-04-2020 19:44
09-04-2020 19:44
You're welcome @Belinda44, your reply is also appreciated.
I'm sorry to know that your issue persists but thank you for taking into consideration the troubleshooting steps from my previous post. That being said, let me share with you that our Customer Support team was contacted on your behalf to provide you further assistance with the difficulties you're currently experiencing. Please keep an eye on your email inbox because they'll be in touch with you pretty soon.
In the meantime they contact you, let me know if you have any additional questions.
09-05-2020 02:04
09-05-2020 02:04
Hello, I am having the same problems, have restarted 5 times but cannot shutdown as touch screen feature not working so cannot swipe to get to settings.
09-06-2020 18:21
09-06-2020 18:21
Welcome aboard @SpaceGipsy
Thanks for your post and for taking into consideration the troubleshooting steps from my previous post. To move forward with this, can you please confirm which Fitbit are you using? Do you have the Versa, Versa Lite or Versa 2?
I'll be waiting for your reply.
09-06-2020 18:29
09-06-2020 18:29
09-07-2020 23:49
09-07-2020 23:49
I have the Versa 2
09-08-2020
06:25
11:46
RicardoFitbit
09-08-2020
06:25
11:46
RicardoFitbit
I was able to fix mine by changing the clock face to one of the other free clock faces. Now it’s working.
Denise Hinxman
Moderator Edit: Personal info removed
09-08-2020 06:37
09-08-2020 06:37
09-08-2020 08:44
09-08-2020 08:44
Me too. I have reset it 3 times. It is only on the clock screen
09-08-2020 08:48
09-08-2020 08:48
Hi, this did not work for me.
09-08-2020
08:53
11:46
RicardoFitbit
09-08-2020
08:53
11:46
RicardoFitbit
I'm using the mountain bike clock face. And I resynced.
Denise Hinxman
09-08-2020 09:35
09-08-2020 09:35
I have tried all of the responses above and my screen still won't swipe. I have changed the clock faces and restarted by holding button down for 10 seconds several times. Please help!
09-08-2020 19:24
09-08-2020 19:24
Thank you Denise but I have already tried this several times and with several clock faces but it hasn't solved the problem and screen still not swiping
09-08-2020 19:55
09-08-2020 19:55
Same situation for me! Please help!
09-08-2020 21:15
09-08-2020 21:15
I'm having the same issue. I've changed the clock face several times. I've restarted several times(can't factory reset). I've removed the device from the app and put it back on. I've uninstalled and reinstalled the app. Nothing works. Please help.
09-09-2020 00:56
09-09-2020 00:56
09-09-2020 16:54
09-09-2020 16:54
So, I put my device on the charger for about 5 hours (the battery wasn't low) and it seemed to do better this morning. It was still a little glitchy freezy (technical terms), but I was able to get to the settings to do a hard reset. I had to hard reset 2x today and remove the device from my app and resync it. It seems to be okay now.
09-10-2020 14:20
09-10-2020 14:20
Thanks for the advice, just tried this but unfortunately it’s still not working. Cannot swipe to get to settings
