02-19-2020
02:56
06:32
JuanJoFitbit
02-19-2020
02:56
06:32
JuanJoFitbit
My side button has stopped working. The watch is only a few months old so this is quite annoying. Has anyone dealt with a similar issue before?
Moderator edit: format
11-15-2021
19:20
12:28
AndreaFitbit
11-15-2021
19:20
12:28
AndreaFitbit
my Versa 2 side button does not work and can not sync with app
Moderator edit: format.
Best Answer11-16-2021 13:29
11-16-2021 13:29
me too i tried all troubleshooting is there anything else I can do or am I gonna have to get a new one?
Best Answer11-16-2021 13:49
11-16-2021 13:49
tried this didnt work
Best Answer03-04-2022 05:23
03-04-2022 05:23
This did not work for me. The button pushes easily, but the watch does not respond. Mine is stuck on the wallet set up.
03-09-2022 07:13
03-09-2022 07:13
My Versa2 Fibit is less than 2 years old. The side button no longer works as I see seems to be a common issue. What is the best way to go about contacting someone regarding this?
Best Answer03-15-2022 08:01
03-15-2022 08:01
How do I get help because I’m having the same problem. I have a Fitbit versa 2 and the side button is not working. When I can get the screen to come on it’s on the Settings page and it won’t change.
Best Answer03-15-2022 14:58
03-15-2022 14:58
You need to contact support. Go to your profile icon in upper right hand corner and click Contact Support. You can chat or call them.
Best Answer03-15-2022 16:04
03-15-2022 16:04
Mine Versa 2 is not working at all. I tried to do the chat with support and they had me try multiple steps without success. Then they said I would get an email about the warranty, but I didn't get one. Then I called the support line and was told that there was a lot of calls recently and the "email team" was behind in sending out emails. My Versa 2 still is not working and still no email. Frustrated. I like it and don't want to switch to a new brand or Iwatch.
Best Answer05-06-2022 11:11
05-06-2022 11:11
I am currently having the same issue and have been since Feb and I got my fitbit in January
Best Answer06-27-2022 17:53
06-27-2022 17:53
My left button isn’t working either. Reached out on Twitter and they said reset. But I can’t because the side button doesn’t work. And I can’t set the alarms on it. They are giving me the run around instead of a new device.
06:36
16:50
DavideFitbit
09-02-2022
06:36
16:50
DavideFitbit
I feel like this must be a known issue to the manufacturers. My side button stopped working, but my Fitbit Versa 2 was few weeks out of warranty, so the only thing offered by the manufacturer was a discount on another one (and not a large discount). I went without a Versa 2 for a while and then found a great deal on a new Fitbit Versa 2 through a reputable company. Against my better judgment, I bought a new Versa 2. This one was only nine months old when the left button stopped working. In this case, since it was less than a year old and since I bought it through a reputable and known partner, I was able to get it replaced rather easily. I am waiting on the new one now, although I don't have much faith that the button will last on this one either. The only two Versa 2s I have owned developed the exact same issue rather quickly. (And, no I do not get my Fitbit wet, so it can't be that.)
I have dealt with this issue twice. The second time around my Versa 2 was less than a year old and I contacted customer support via chat and they offered me a replacement or a discount on another Fitbit product.
09-12-2022 11:04
09-12-2022 11:04
My side button also stopped working. The device is only 3 months old. I bought it through Amazon. Do I return it to Amazon or Fitbit for replacement?
Best Answer09-12-2022 15:44
09-12-2022 15:44
Best Answer02-01-2023 12:36
02-01-2023 12:36
The same thing is happening with mine!
