01-13-2020
12:53
06:12
JuanJoFitbit
01-13-2020
12:53
06:12
JuanJoFitbit
Bought my versa around Oct 2019. Used to work well but now the touch doesn't work, i cant pass the password screen. I only see time and call notifications only 😞 i tried both android and ios but the issue is the same.
06-05-2020 08:06 - edited 06-08-2020 08:00
Hi there @FernandoPetri, welcome to the Community Forums. I'm sorry to hear that your Versa 2's screen isn't working. I appreciate you've taken the time to troubleshoot it prior to posting here.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual. We hope you get back on track soon.
Hello @EGE2020, I'm sorry to hear you go. Please don't hesitate to reach out to us if there's anything else we may do for you in the near future. Have a good day!
06-05-2020 08:32
06-05-2020 08:32
06-06-2020 20:01
06-06-2020 20:01
Got my versa 2 in Dec 2019. Screen has not been working intermittently since. Restarts have helped in the past, up until the last 2 weeks. I've restarted it multiple times as suggested above and changed the clock face too. I have tried to start a support chat, but redirects me to a page where it can't load? This device is basically useless to me at this point.
06-07-2020 01:56
06-07-2020 01:56
Hi,
I have the same problem with everyone. My touch screen doesn't work. I tried everything you mentionned. I restarted, I changed the clock face, I turned off quick view. But It doesn t change anything. I still I can not access to the settings on my device. So I can not reset the factory settings. What should I do?
06-07-2020 07:00
06-07-2020 07:00
06-07-2020 08:15
06-07-2020 08:15
06-08-2020 08:10 - edited 06-08-2020 08:29
Hi there @Allyjabo, welcome to the Community Forums. I've seen that you've got in touch with our Support Team after posting here and they've helped you to get your issue solved.
Hello @Sheetal123, thanks for stopping by. We're glad to hear that you're getting a replacement after contacting out team.
Hi @ZeynepT, welcome to the Community Forums. I'm sorry to hear that you're going through this situation with your Versa 2's screen. I've created a case to get you in contact with our Support team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Note that we may take a bit long to get back to you due to recent events affecting our operations, support options are limited and wait times are longer than usual.
Let me know if there's any questions present.
06-09-2020 12:43
06-09-2020 12:43
Hi there,
I purchased a Versa 2 back on December 2nd and the screen is not responding to touch. I've performed the recommended steps to mitigate the issue and updated the software, but it is still not working. Please kindly advise.
Thanks!
Kevin
06-09-2020 23:37
06-09-2020 23:37
I removed all the application installed in the watch using phone app and now with only 5 app icons watch is running like a charm including responsive touch screen.
Current set of apps icon available in the watch are
1. Exercise
2. Alarms
3. Weather - only 2 locations
4. Settings
5. Clocks - only 1 default clock face.
Rebooted, pushed the latest update and thats it. Now it is working like almost brand new. Hope this helps. Good luck.
06-10-2020 01:58
06-10-2020 01:58
06-10-2020 16:34
06-10-2020 16:34
Bought my watch in February, and it began doing this in May. I was issued a replacement and now the replacement is doing the same thing. The touchscreen just stopped working. I can’t swipe in any direction or go to apps. I bought this to track my exercise and now I can’t do that at all. And this was supposed to be the replacement to the broken one. I am so disappointed with the $250 I spent.
06-11-2020 10:01
06-11-2020 10:01
Hi there @hikeaway, thanks for getting back and sharing your workaround. Let me know how it goes in the next couple of days.
Hello @basscraft. I'm glad to hear that your replacement is working fine so far. I'll be around if there's anything I may do for you.
Hey @KatyKat5, welcome on board. I'm sorry to hear that you're going through this situation with your replacement. I'm here to help you.
If you haven't done so yet, please try the following steps:
Tried to change the Screen Wake setting to manual, you can find the steps to do it in this help article: How do I see the time on my Fitbit device?
If those steps don't work, would you mind trying what @hikeaway recommended here?
Let me know the outcome.
06-13-2020 18:54
06-13-2020 18:54
I have done all the suggestions and it still doesn’t respond. Please advise.
06-13-2020 21:00
06-13-2020 21:00
I did that and then did the new update and my Fitbit started working again it was more of a miracle and I did not know how
06-15-2020 07:02
06-15-2020 07:02
Hi there @Aturn22, welcome here. Thanks for letting me know that you've followed the troubleshooting steps provided in this thread. I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Note that we may take a bit long to get back to you due to recent events affecting our operations, support options are limited and wait times are longer than usual. We hope your issue is solved soon.
Hey @Ityagirladdie, thanks for the update. I'm glad to hear that you're now back on track.
I'll be around if there's anything else I may do for you all.
06-15-2020 11:27
06-15-2020 11:27
Hello @MarreFitbit
I did as you suggested: changed the clock face, restarted, turned on manual wake, and it still did not work. I also did the suggestion with deleting apps and that also did not work.
I took it a step further and removed the versa from the app and completely rebooted and reconnected it and still the touchscreen is not working. I have noticed that it is also not counting “floors” anymore either.
I checked, and it does not have an update either.
This is all on my replacement Fitbit for my original whose touchscreen stopped working.
06-15-2020 11:45
06-15-2020 11:45
Hi there @KatyKat5, thanks for getting back. Thank you so much for following the recommendations provided, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know. 😉
06-15-2020
11:47
11:56
06-15-2020
11:47
11:56
06-15-2020 11:49
06-15-2020 11:49
It was a pleasure @KatyKat5!. Have a good day!
06-17-2020 21:59
06-17-2020 21:59
The suggested solution did not work for me. Facing still same issue. Unable to receive call, navigate to any options. Please resolve
