09-06-2023
10:58
04:18
09-06-2023
10:58
04:18
~ 2+ year old Versa 2 that had no previous issues just stopped syncing. Tried all the tricks I can think of... reset, hard reset, delete program, reinstall program...
Watch begins the process of pairing... shows up in the Bluetooth section on different devices... begins connection/setup/syncing process then stops
Perfermed hard reset after the soft reset didn't fix the Bluetooth issue and now the watch's face just boots to the fitbit welcome and loops...
Any additional ideas will extremely welcomed... TIA
09-08-2023 04:26
09-08-2023 04:26
Hi there, @NBStwo @Try0 @IFleming. Welcome to the Fitbit Community Forums. Thanks for the details provided in your posts about the issues with your Fitbit devices and the time you've taken in order to solve the inconvenience. There are still some steps we can try!
I totally agree with the tips and recommendations provided by @JH23 and @nit819 (I'm glad you both are back on track, btw!). So, let's try the following steps in the order listed:
With the steps above, what I want you to do is to pair your Fitbit device first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
09-06-2023 14:09
09-06-2023 14:09
Hi. Mine has just done this in last 2 days. Have uninstall and reinstalled the app, reset the fitbit. The watch still records my steps etc fine, but can't pair with phone and phone says "this device needs an app to work"
09-07-2023 10:04
09-07-2023 10:04
If you haven’t already, try turning your phone off for a few seconds. Took care of the problem for me. Hope this helps
09-07-2023 14:52 - edited 09-07-2023 14:53
Try turning off Bluetooth on your other devices. I had syncing issues of this sort with my own Versa 2 watch until I figured out that my watch was connecting with my computer rather than my cellphone. Turned off the Bluetooth on my PC and syncing started happening normally again.
I figured this out when I found out that my watch would sync normally when I'm outside of my house (when PC is out of range), meaning something in my house was interfering with the syncing process.
09-07-2023 15:30
09-07-2023 15:30
Me too. For 3 days.
09-08-2023 04:26
09-08-2023 04:26
