12-20-2019 10:01
12-20-2019 10:01
Hi there @Jkh105, welcome to the Community Forums. Thanks for restarting your Versa 2 prior to contacting us.
I've created a case to get you in contact with our Support team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you.
Best Answer02-11-2020 10:07
02-11-2020 10:07
I'm having the same issue. Ive only had my versa 2 for just over 2 months
02-14-2020 08:29
02-14-2020 08:29
I am having several issues with my Fitbit and very disappointed. For the cost of these there should not be such a struggle to get it to work.
02-25-2020 09:05
02-25-2020 09:05
Won’t scroll off main screen.
Best Answer03-05-2020 08:38
03-05-2020 08:38
I have the same issue and I've only had mine for ❤️ weeks
Best Answer03-15-2020 20:20
03-15-2020 20:20
Can I get an update on this issue as well. I cant scroll off the main screen and I am getting random reboots along with buttons not responding. I am at the end of my patience with this device and currently shopping for a different smartwatch.
03-15-2020 20:31
03-15-2020 20:31
Mine just started doing this too, and will randomly restart itself. I did a factory reset and it worked for an hour and then started doing the same thing again. I've only had my versa 2 for a month so this is very frustrating, especially for how much these things cost.
Best Answer03-16-2020 01:46
03-16-2020 01:46
Ive got the same problem. Ive reset it, now the screen says Reset Fails, but I cant interact with the screen in any way. Its literally a couple of weeks old and cost $340!!!
Best Answer04-02-2020 08:03
04-02-2020 08:03
Same her . No scrolling off the clock. Just got this a couple of months ago and it's in perfect condition.
Best Answer04-02-2020 08:58
04-02-2020 08:58
Best Answer04-02-2020 11:40
04-02-2020 11:40
Best Answer04-05-2020 06:01
04-05-2020 06:01
Hi! I have the same problem and the scroll is not working even after reset pls help! - Jay Lim from Philippines
Best Answer04-05-2020 08:10
04-05-2020 08:10
Restarted multiple times and it still will not swipe.please help
Best Answer04-22-2020 06:44
04-22-2020 06:44
My versa 2 won't scroll. I have had it since Christmas. Please advise.
Best Answer05-21-2020 10:52
05-21-2020 10:52
I'm having the same issue, can you please help?
05-21-2020 10:53
05-21-2020 10:53
Hi, I'm having the same issue. Did you receive an update?
Best Answer05-21-2020 11:59
05-21-2020 11:59
I wrote to fitbit and told them what was happening. They replaced it, there is no fix. It’s a fault with them and fitbit are aware of it.
Best Answer05-21-2020 12:01
05-21-2020 12:01
05-21-2020 12:01
Thank you so much, I'm in contact with them now.
