11-03-2019 01:39
11-03-2019 01:39
My 6 week old versa 2 won’t swipe up or across, any advice would be appreciated x
11-03-2019 03:04
11-03-2019 03:04
Hi @Joaniejoan26, welcome to the community.
Have you tried restarting your Versa 2 by pressing and holding the button for 10 seconds (until you see the fitbit logo)?
Best Answer11-03-2019 03:45
11-03-2019 03:45
11-03-2019 04:20
11-03-2019 04:20
I’m having the same problem. Can’t swipe and screen is not responding when tapping. Less than 4 weeks old. I’ve tried resetting and a factory reset and still not working.
11-04-2019 22:23
11-04-2019 22:23
I am having the same problem, also have my Versa 2 for about 6 weeks. For the past week, this issue keeps recurring — I can’t swipe from the top or sideways. I restart the watch and it works, but the problem comes back in the same day.
11-05-2019 00:14
11-05-2019 00:14
01-06-2020 04:18
01-06-2020 04:18
Having the same issues. Started right away after using, but I thought it was my user error. Turns out that now it won’t swipe in any direction and have reset. Can’t factory reset because can’t access that part of screen. Using a Fitbit face (Bitmoji)
01-17-2020 22:37
01-17-2020 22:37
I am done, too. This is my 4th Fitbit, my first Versa 2 and have had it less than two months and have had problems with the clock faces giving wrong times three times and now the swiping is intermittently. The previous Fitbits I had were the HR models which had band issues and battery recharging issues. Really liked the functionality which was the reason I went out on the limb and decided to try the Versa 2 really loved it's features until about 3 weeks ago when the clockface stopped working and was unable to synch and now with the swiping not working, I am done. Time to try a competitor brand probably the Apple. Hope Fitbit really examines why their product quality is so poor and most importantly improves it. I am done and hope other users have better results...
Best Answer02-19-2020 16:53
02-19-2020 16:53
I’m having the same problem. I have to restart multiple times a day. I’ve also found it is draining my battery life.
02-19-2020 20:36
02-19-2020 20:36
Penny, I wish you success in getting a resolution to your problem. Because I had purchased 3 different Fitbits over the past 6 years and had problems with each of them, the last being the Versa 2, I decided to check out competitor fitness watches. First I tried a Samsung model that I did not care for at all.
I now have an Apple 3 watch and am very pleased with its capabilities. Hopefully, in the long term, I will have better success with it in terms of technical and functional issues than I experienced with Fitbit products. Again, Penny, I hope you get a positive resolution to your issues.
Take care, Jean
Best Answer03-01-2020 17:23
03-01-2020 17:23
I'm having this issue as well. I have restarted the watch, changed the clockface and have done a factory reset but am still having issues. I have had this watch since the end of December.
Best Answer03-01-2020 19:41
03-01-2020 19:41
neridam, i purchased mine around the same timeframe. Because of other problems I had with previous Fitbit, I returned my Versa 2 to purchase an Apple 3 watch about a month ago. So far I am pleased with it and hope I do not encounter the same problems I had with Fitbit watches. I hope you have better success than I did to get a better resolution to your issue.
Best Answer03-01-2020 19:48
03-01-2020 19:48
Having the same issues. Received my watch in late January. I have to reboot the watch multiple times a day as it continuously stops responding to tapping, arm movement or swiping. I have factory reset - no change.
Sometimes it will come back to life when it gets a notification through for emails or text from my phone.
Best Answer03-01-2020 21:44
03-01-2020 21:44
Redbill, as you may see from my previous replies, I returned my Fitbit. Now have Apple 3 and hope it will work better than the Fitbit watches I purchased. I wish you success in getting hopefully a better resolution than I did mine.
Best Answer04-08-2020 10:12
04-08-2020 10:12
I have a 4 month old Versa 2 with the same problem. Have you found a solution?
Best Answer04-08-2020 10:14
04-08-2020 10:14
I have the same problem, have you found a solution?
Best Answer04-08-2020 11:40
04-08-2020 11:40
Support sent me a new watch
Best Answer04-08-2020 13:18
04-08-2020 13:18
Best Answer04-08-2020 14:05
04-08-2020 14:05
Hi all!
I've been living with the problems for over a month now as I've had other things more important to take care of. I called customer service today and gave them my prior case number. After a full charge this morning, I took a walk using GPS from my phone app. When I got back, my battery was at 26%!!! They agreed with my that my watch is having more than 1 problem. I was sent a form to complete and am now waiting for a replacement device.
Good luck to you!
Best Answer04-08-2020 14:07
04-08-2020 14:07
Call the customer service number. I previously tried the online chat and I was pretty much sent away to try their "fixes". I called today and explained the problems. I am now waiting on a warranty replacement to be sent.
