01-27-2021 06:22
01-27-2021 06:22
My versa 2 will not sync after I did the update. I have it fully charged, my phone is up to date, and cannot find any reason for it not to be synching. Getting really annoyed.
01-27-2021 06:27
01-27-2021 06:27
Was this an update to the android app version 3.37? If so, there seems to be a bug with it that Fitbit are investigating.
Best Answer01-27-2021 06:33
01-27-2021 06:33
Best Answer01-27-2021 08:35
01-27-2021 08:35
My fitbit is exactly the same. Will not sync. Have uninstalled app. Turned phone off and on. Turned watch on and off. This hasn't synced for 2 days now. Sooo annoyed.
Best Answer01-27-2021 08:48
01-27-2021 08:48
Mine is also the same issue. Its not sync for the last two days. Can anyone help me
Best Answer01-27-2021 09:03
01-27-2021 09:03
Same issue here. My phone is not showing as compatible with the Versa 2 (I have an LG Stylo 4). I tried to sync to a chromebook but found that doesn't work either. I contacted fitbit and they told me the problem is incompatibility with my phone. But for months previously it has worked just fine. All of a sudden two days ago it stopped. I also asked for a way to transfer the existing data on my watch to the computer via USB or another method -and there is none.
Best Answer01-27-2021 09:21
01-27-2021 09:21
Best Answer01-27-2021 13:40
01-27-2021 13:40
