01-25-2021
07:39
11:02
01-25-2021
07:39
11:02
My versa 2 couldn't sync on one plus 8 pro
@Suman-27 Thanks for the details provided in your previous post.
As I've mentioned in this post of mine, please make sure that your OnePlus 8 Pro phone meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
Hi there @Suman-27, welcome to the Community Forums.
Before anything else, please note that your OnePlus 8 Pro device is not yet officially compatible with the Fitbit app which would explain the syncing difficulties you're running into. To check the list of compatible devices, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
Moving on to the troubleshooting steps, see Why won't my Fitbit device sync?
Best AnswerThanks merry for you attention. i wear versa 2 since last 2 year. But One plus 8 pro doesn't work at all. So how can i fix the problem. It doesn't sync . Plz give me a technical assist. Thank you
