01-11-2022 10:43
01-11-2022 10:43
Hi, hope someone can help, I’ve just had my daughters versa 2 and I am having trouble syncing to my iPhone, I’ve tried the turning Bluetooth off and on etc and I still can’t find it through the Fitbit app, advice would be welcomed. Thanks
01-11-2022 14:20 - edited 09-02-2023 07:35
Hi there, @SunsetRunner. Welcome to the Community Forums.
To better assist you with this, may I know if the Versa 2 belonged to your daughter, but now it belongs to you? Or your daughter just received a Versa 2 which you want to sync to your iPhone? Are there two Versa 2 devices that you want to set up and sync to your iPhone? Have you both created a separate account for each?
If your issue is the first sentence, I've described, please know that the Versa 2 cannot connect properly to your phone since your daughter hasn't yet forgotten the connection between the Versa 2 watch and her phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
Best Answer01-11-2022 14:20 - edited 09-02-2023 07:35
