09-24-2023
12:16
04:51
09-24-2023
12:16
04:51
My Versa 3 recently seemed to have a factory reset for no apparent reason. Now the controls for notifying calls etc won’t work despite trying to reconnect them several times. It’s very frustrating. Has there been some update that has skewed things? The watch is only about5 months old so not very happy.
09-25-2023 04:55
09-25-2023 04:55
Hi there, @Fitlass. Welcome to the Fitbit Communtiy Forums. Thanks for the details provided in your post about the issue with your Versa 3 and your time in trying to troubleshoot it before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration. @Guy_ Thank you so much for your help!
Since your Versa 3 went into a Factory Reset, please try the following steps in the order listed:
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
09-24-2023 20:16
09-24-2023 20:16
Hi @Fitlass - if the watch factory reset it will need to be fully set up again in on wrist calls, which may entail going to Bluetooth on the phone and turning it on, also there is a setting in watch Settings for calls.
If it is still problematic one option is to remove both the watch Bluetooth entries from the phone and in the Fitbit App, logout and login, click profile photo and "+ set up a Device" and replace to make sure the entries are made again and configure on wrist calls again.
09-25-2023 01:22
09-25-2023 01:22
09-25-2023 04:55
09-25-2023 04:55
