01-01-2021
02:15
20:50
01-01-2021
02:15
20:50
Hi, I had the versa 3 for Christmas and the straps keep coming disconnected and my watch falling off, is this a common fault or is there anything I can do to fix this?
03-08-2023 14:38
03-08-2023 14:38
How did you contact fitbit? I am in contact with them now for 2 months and I have to send picture and video's and they still believe it is a user error. It is unbelieveble..
Best Answer03-08-2023 14:41
03-08-2023 14:41
Hi I am chatting with Fitbit a couple of times and every time they direct me to a blog about how to attach the straps. It is unbelievable. This is my first experience with fitbit and there is an error with the clips. I cant wear my fitbit. I have send videos and picture I can describe exactly what the problem is. What can I do more?
Best Answer03-08-2023 14:44
03-08-2023 14:44
03-08-2023 14:44
I got no response
Best Answer03-08-2023 15:52
03-08-2023 15:52
Best Answer03-08-2023 20:52
03-08-2023 20:52
Hi, I actually contacted thru Twitter. I sent a DM to chat there. Also sent photos. Hope this helps! Good luck!
Best Answer05-02-2023 17:17
05-02-2023 17:17
I've had the same problem. Lost the watch add a result. The attachment is garbage
Best Answer07-03-2023 10:07
07-03-2023 10:07
Mine is the same another band than the plastic one comes straight off usually the top one. The bottom one is fine.
