01-01-2021
02:15
20:50
01-01-2021
02:15
20:50
Hi, I had the versa 3 for Christmas and the straps keep coming disconnected and my watch falling off, is this a common fault or is there anything I can do to fix this?
Hi there @Toria88, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3.
This shouldn't be happening, so please confirm that you're attaching the bands by pressing them into the end of the watch until you hear a click and each of them snaps into place. The band with the loops and peg attaches to the top of the watch. For step-by-step instructions, review the user manual for Versa 3 pag.15-16.
Let me know how it goes.
09:55
13:08
01-01-2021
09:55
13:08
I’ve followed all the instructions and it clicks in but after wearing it for a while it just drops off my wrist. The clips to hold is in is a lot loser than the other side that holds the other strap fine
I’ve just taken the strap off that’s ok and clipped it back in and the side that keeps coming loose doesn’t ‘click’ into place like that one so I think the clip is faulty
Get Outlook for iOS
Moderator Edit: Merged posts
@Toria88 I appreciate you've taken the time to follow the tips and recommendations I provided. I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best AnswerHi @MarreFitbit I'm having the same issue with my Versa 3 bands. I think the issue is actually with the FitBit though because I have different bands that used to snap into place and now the top ones don't. Are you able to help with this? Thanks!
Hi there, @chibbert. Welcome to the Community Forums. Thanks for sharing the details about the issue with the bands.
As a first step, I'd recommend following the suggestion I've shared here. If you've done that already but to no avail, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best AnswerHi Marre
i have followed your instructions and have not been able to fix my straps since I had to purchase new ones. They will not lock into the watch. I guess I should have listened to my friends and bought the apple watch
Hi,
I have been having the same issues for a week now. I make sure that both the bands are clicked in, wear the watch for a couple hours then the band falls off randomly throughout the day. Not sure how to fix it.
thanks,
Madison
Hi there, my son recently received a Versa 3 as Xmas gift and unfortunately has been experiencing the exact same issue with the faulty clip causing one side of the band to fall off randomly. We have tried all troubleshooting to ensure it is a defect. We really need your assistance on next steps to resolve this asap. Thank you very much!!
Hello Maria. I have a Versa 3 that is having the same issue as others have referenced here. I tried the steps you outlined above and the strap is still failing to stay connected.
Please create a case to get me in contact with your Support Team about this.
Thank you
im having the same issue too.
only one part of the strap that connects to the watch face disconnects .
the strap connector on the watch face of that strap is slighty looser then the other strap connector, which has never had an issue. (touchwood).
please advise on my watch too please
Dan,
I never got a reply here from Fitbit. So a couple days later I messaged them through the app and they sent me a free replacement. Message them through the help center in the app. Easiest fix
Mine also faulty. Definitely a defect. How can I get this replaced? Not good enough. Had for 3 months.
Best AnswerI have the same problem with the band not clicking into place. I've had 4 of these 3rd party bands (2 metal and 2 leather) that just won't attach. All of them have a problem with the top band, the one with the loop. If I put that band at the bottom, it still won't click. What's strange is that the original band and the 3rd party silicone bands I bought all click securely. What's even stranger is that there are no visible differences in the structure of the "attacher" between bands that click securely and those that don't.
I hope Fitbit can figure out what's wrong.
I have exactly the same problem. The top band, doesn't click into place.
I thought the original silicone bands had a magnetic final closing system. And that was the reason that one would fit, but I am not sure. I bought 3 third party bands and 1 fitbit vegan leather. All won't connect with the top of the fitbit.
I am now in contact with Fitbit. They are advising the woven band, but since I already tried 4 bands I am a little sceptic about this.
But I am allergic to the silicon band, so I have to try it. Now it is so bad that I can't wear my fitbit everyday to let my skin heal..
I am allergic to silicone too. My versa 2 never had issues with bands so this is depressing since I got this upgrade for 🎄.
