Versa 3 battery is draining quickly
ANSWERED
So my Versa 3 battery has been draining rather quickly in the last week or so and I called Customer Service and they said that they are aware of the problem.  Apparently this happened as a result of an update. They said that they are working on the problem.  So far no resolution.  Anyone else have this issue?
1 BEST ANSWER
Accepted Solutions
Hi there, @leelee64905. Welcome on board. Thanks for making sure you do not have the "Always-on" display enabled.
Aside from this feature, I'd like to share with you in case you're using Snore Detection that this feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
All tips and recommendations to prevent your device's battery life can be found here
Hope that helps.
8 REPLIES 8
Hi there, @Mav0109. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
Please feel free to reach out to our Support Team once again if you have any further questions or concerns regarding the outcome of your case. Since you have reported this matter to our Support Team, please note there's nothing left we here in the community can suggest other than reaching out to our team again.
Nevertheless, I'd like to share with you in case you're using Snore Detection that this feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
Also note that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
See you around.
Hi Mav0109
i have the same issue with my battery. I don’t have the ‘always on’ activated either.
have you managed to remedy this yet?
Hope that helps.
No not yet but someone said that the snoring feature uses a lot of battery so I turned that off to see if that makes a difference.
Sent from Yahoo Mail for iPhone
@Mav0109 Keep me posted!
Yes! I turned off GPS, disconnected the voice assistant, and turned down my screen brightness and I'm barely getting 24 hours after a full charge which is annoying. I can't participate in challenges when my Fitbit has to be on the charger everyday. I'm starting to regret my Versa 3 purchase and should have stuck with my Alta HR. I was getting 8 days of use before needing a charge with that one. I hope they fix this soon.
Some posted for me to turn off the snore monitoring feature because it uses a lot of batter.  I did that ( never selected to have it on) and it does last a bit longer.  Still not good.
@Mav0109 @AdiaS I appreciate you had followed the tips and recommendations provided above. I understand how you must be feeling.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
