11-30-2021
13:54
20:43
11-30-2021
13:54
20:43
The side button of my Versa 3 is stuck, pushed in
11-30-2021 14:30
11-30-2021 14:30
It doesn't really go in or out. It is just touch sensitive. It always looks like it is slightly in.
11-30-2021 22:12 - edited 12-01-2021 05:13
Hi @heleenie - @JohnnyRow is correct. Practice turning on and off the display till you get the knack of doing it, using this process to get started.
Worn on the left arm -
rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch the fleshy part of the thumb will make the button work using your nail won't work. |
12-08-2021 15:15
12-08-2021 15:15
Best Answer12-08-2021 16:48
12-08-2021 16:48
Are you sure you are talking about the Versa 3 and not the Versa 2?
Best Answer09-25-2022 12:52
09-25-2022 12:52
Same here. Not even sure how it got pushed in. Will no longer charge.
Best Answer09-25-2022 18:04
09-25-2022 18:04
Hi @deadon2 - the versa 3 has a haptic button which you cover to make work, so that is not the problem. You won't be able to use it though if the battery is not charged.
The most likely reason it won't charge is there is either a faulty charge cable or the watch contacts need good cleaning, see instructions in this link How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer09-26-2022 18:31
09-26-2022 18:31
Versa 3s have digital buttons, not actual ones. It can't get stuck. Try shutting down the watch, waiting, and turning it back on. Or wait for it to run out of power.
