12-30-2020
14:13
20:50
12-30-2020
14:13
20:50
My Versa 3 is paired, but not Versa 3 controls. How can I get the Versa 3 controls to pair? It keeps saying it cannot pair.
08-21-2021 20:59
08-21-2021 20:59
My watch will pair with my bluetooth amd my versa 3 controls will not i did all the steps as recommended with turning off and on again? Everything was working GREAT before the update and now its not so fusterating.And even looking over my shoulder for me wouldnt help this messy situation!!
08-21-2021 21:02
08-21-2021 21:02
Im in the same boat. Everything was working great UNTIL the update .Now my controls womt sync amd my battery only last a day and a half instead of 2-3 days! So annoying and these are not cheap.
08-22-2021 21:33
08-22-2021 21:33
Thanks Rich. I tried the steps as you instructed but both the phone and the versa kept searching and then after several minutes gave up. The "versa control" disappeared from the iphone's bluetooth and the versa 3 controls setting on my watch turned itself off again. I tried again a few more times with the same outcome. Thanks, Dave
08-22-2021 22:23
08-22-2021 22:23
The versa controls will not search, you need to put controls into their discovery mode for the phone to find the controls.
Make sure that the controls. Are removed from the phone. Then shut off both the phone and versa to restart the hardware
08-23-2021 01:24
08-23-2021 01:24
Alright Rich! That worked! Woohoo. Thanks!
08-25-2021 13:01
08-25-2021 13:01
Glad to hear this @DaveMoe
01-06-2022 18:48
01-06-2022 18:48
My Versa 3 controls doesn’t show up on the Bluetooth list & I have an iPhone 12. It showed up once but no longer.
09-01-2022 13:33
09-01-2022 13:33
That has not been my experience. When I first set it up the versa 3 controls would connect, but after a while it stopped working.
04-18-2023 09:05
04-18-2023 09:05
I was having the same issue. Try restarting the Versa 3, wait 15 seconds, then trying the pairing process again. This did the trick for me, and I was about to give up and return it.
07-04-2023 07:54
07-04-2023 07:54
Where do I turn controls on? Can't find that on the device
