06-08-2022
08:35
17:58
06-08-2022
08:35
17:58
06-09-2022 08:40 - edited 11-15-2023 06:20
Hi there, @Harjot485. Welcome to the Community Forums.
If the steps recommended by @SunsetRunner don't work, I suggest following the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
06-08-2022 11:39 - edited 06-08-2022 11:42
Hello @Harjot485
Try restarting your Versa 3: https://help.fitbit.com/articles/en_US/Help_article/1186.htm. You will not lose any data doing a restart. If that doesn’t help try changing the clock face: https://m.youtube.com/watch?v=kHyuhNFtTIk
😃I’m hoping that gives you the fix you need. Let me know how it goes
Hope that helps.
