Versa 3 is stuck in a boot loop
ANSWERED
Versa 3 on bootloop please help
1 BEST ANSWER
Accepted Solutions
Hi there, @Harjot485. Welcome to the Community Forums.
If the steps recommended by @SunsetRunner don't work, I suggest following the steps below in the order listed:
  • Unpair your Versa 3 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Restart your Versa 3 one more time.
  • Set up your Versa 3.
  • If there is no connection, restart your Versa 3 once again.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
2 REPLIES 2
Hello @Harjot485
Try restarting your Versa 3: https://help.fitbit.com/articles/en_US/Help_article/1186.htm. You will not lose any data doing a restart. If that doesn’t help try changing the clock face: https://m.youtube.com/watch?v=kHyuhNFtTIk
😃I’m hoping that gives you the fix you need. Let me know how it goes
I show you to change the clock face display (watch face) on a Fitbit Charge 3 or Charge 4. Fitbit Charge 3 Fitness Activity Tracker: https://amzn.to/2SEtJkl Fitbit Charge 4 Fitness and Activity Tracker: https://amzn.to/2ywpct8 Amazon Daily Deals: https://amzn.to/2QVcoRC -----My Gear for Youtube ...
Hope that helps.
