03-25-2024
02:29
11:59
LizzyFitbit
03-25-2024
02:29
11:59
LizzyFitbit
After only 12 months my Versa 3 has stopped working - I have tried all the suggestions on the forum and nothing works
I have now had 2 Fitbit watches that have last a total of 3 years. I will not be buying another one
Its a pile of junk
Moderator Edit: Clarified subject and updated label
Hi @Andrewsmith17 - one of the common problems where a watch only plays dead is it isn't charging. See How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
The other is it got wet, if that is the case it is damaged.
As you don't say why it has become not working this is just a guess.
There can of course be other simple options that you may not have found. Finding the right one depends on what the current situation is exactly.
Hi there, @Andrewsmith17. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 3 is still unresponsive. I understand how you must be feeling, we're here to help!
Have you tried what @Guy_ recommended? If so but the issue persists, as our last resort, I'd recommend performing a factory reset on your Versa 3. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
With the above being said, please follow the steps below in the order listed to properly perform the factory reset:
