03-01-2021
08:57
20:47
03-01-2021
08:57
20:47
Hi,
My Versa 3 will not come out of sleep mode using the swipe right shortcut. When I swipe and hit the shortcut, I get the message 'Locked for Sleep Mode'.
The only way I can get it out of sleep mode is to go into settings, go to Quiet Modes and turn it off there. Pretty annoying! This is something that just started in the last couple days. Before that, it was working fine. I have not fooled with any settings in the last couple weeks.
Thanks for your help.
03-02-2021 04:49 - edited 07-05-2024 12:58
Hi there @dinokath, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out and for also following @Guy_'s tips and recommendations.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of the steps you've done, this way you could also avoid repeating yourself once again.
03-01-2021 09:25
03-01-2021 09:25
Worth mentioning that I just did a factory reset and it has not changed the behavior.
03-01-2021 10:13
03-01-2021 10:13
Check your sleep schedule.
On the watch Settings Quiet modes Scroll to Sleep mode Scroll to & Click SCHEDULE MODE Turn on Off hours Setup the appropriate times - you have it 24 hours Try turning off the schedule also. |
03-01-2021 10:51
03-01-2021 10:51
Yep, did all that before posting. Was hoping someone from #fitbit would chime in here!
03-01-2021 10:56
03-01-2021 10:56
did you try
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
And resync your watch
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
For IOS uninstall/reinstall the Fitbit App and resetup your Notifications.
03-01-2021 11:13
03-01-2021 11:13
Nope. Still the same behavior. I appreciate your help!!
03-01-2021 11:27
03-01-2021 11:27
Thanks, Interesting issue..
Have you enabled Device lock, or use Fitbit pay?
Does it behave differently when charging?
03-01-2021 12:58
03-01-2021 12:58
No to lock and pay. I don't mess with it while it is charging but when I charge it tonight, I will mess with it a bit and see.
07-27-2021 05:02
07-27-2021 05:02
Same with my brand new FitBit Versa 3 - the touch screen on my watch is unresponsive so I am unable to bring it out of “locked for sleep mode” - what can I do?
07-27-2021 07:34
07-27-2021 07:34
Hi there, @guerinbb. Welcome on board.
Please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face. Then, please try to turn off the sleep mode.
Hope this helps.
07-28-2021 15:40
07-28-2021 15:40
All sorted. Thank you
07-28-2021 16:39
07-28-2021 16:39
@guerinbb Awesome! I'm glad to hear that your issue is solved now. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
08-01-2021 10:37
08-01-2021 10:37
I have the same problem. Fitbit versa 3 stuck in sleep mode. Tried going to quiet modes, saw sleep mode on, tapped many many times, could not turn it off.
scrolled down to schedule , tapped many times, nothing.
followed your advice to restart device . Tried teice, no change.
followed your other suggestion to change click face. That also did not work. Help!
08-01-2021 10:42
08-01-2021 10:42
@SunsetRunner try swipe to the right on the watch to get to quick settings and turn off moon there.
08-01-2021 12:43
08-01-2021 12:43
Thanks. When I swipe right for quick settings I do not see a moon or anything that says moon. I can go into quiet modes but cannot turn off sleep mode or get schedule to do anything
08-01-2021 12:49
08-01-2021 12:49
@SunsetRunner If you have a Versa 3 you should see when you swipe right
its the middle top one to turn off
If you can, also try and Shutdown the watch, at the bottom of Settings.
Place the watch on the charger to restart it.
08-01-2021 13:14
08-01-2021 13:14
10-04-2021 16:04
10-04-2021 16:04
Thank you!!! This worked for me!!!!!!
01-10-2022 08:25
01-10-2022 08:25
Thanks so much! That totally worked! You da man!!!
