Versa 3 stuck on Fitbit Logo
ANSWERED
I installed an spo2 watch face then installed the spo2 tracker.  Since then my watch won't start past the logo.
Is there a way to do a factory reset with only the versa 3 button?
1 BEST ANSWER
Accepted Solutions
Hi there, @William711. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
  • Unpair your Versa 3 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 3 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
To properly use the SpO2 app and clock face, see How do I track blood oxygen saturation (SpO2) with my Fitbit device?
Hope that helps.
1 REPLY 1
Hope that helps.
