07-08-2022
18:07
17:50
07-08-2022
18:07
17:50
I installed an spo2 watch face then installed the spo2 tracker. Since then my watch won't start past the logo.
Is there a way to do a factory reset with only the versa 3 button?
07-09-2022 05:24 - edited 11-16-2023 10:49
Hi there, @William711. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
To properly use the SpO2 app and clock face, see How do I track blood oxygen saturation (SpO2) with my Fitbit device?
Hope that helps.
Best Answer07-09-2022 05:24 - edited 11-16-2023 10:49
Hope that helps.
