06-07-2023
22:27
04:03
06-07-2023
22:27
04:03
My Versa3 won't turn on although the battery is fully charged as shown on the Fitbit App.
Any tips would be appreciated
06-08-2023 04:09
06-08-2023 04:09
Hi there, @Wellnessgal. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
As @Guy_ has mentioned, the battery level on the Fitbit app updates every time you sync. That means that if your Versa 3 hasn't synced yet, your app will still show the battery percentage of the last sync.
If the steps recommended by @Guy_ don't work, as our last resort, I suggest to perform a factory reset by following these steps:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
If none of the steps work, then, please follow @Guy_'s last advice and chat with us online or give us a call. Click here to get connected.
Best Answer06-08-2023 01:40
06-08-2023 01:40
Hi @Wellnessgal - what is shown in the Fitbit App may be misleading if it hasn't synced for a while, so check when it last synced.
When you hold the button for a second and it doesn't start try placing on charge for 5 minutes as that should start it.
If neither methods help, check the charging process in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If that still doesn't work hold the button for 10 seconds till it vibrates and the logo appears.
If that fails the watch may have a fault and you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
06-08-2023 04:09
06-08-2023 04:09
