04-23-2024
05:05
05:03
04-23-2024
05:05
05:03
There’s a typo in the title: Doesn’t**
05-06-2024 22:43
05-06-2024 22:43
Hi @SunsetRunner - if the watch is not faulty, try placing on charge which if that is working should start it. A long button press, if that is working, should too.
If the battery is actually just flat and it's not charging, it won't start. See How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen which explains things to do.
Best Answer05-08-2024 05:07
05-08-2024 05:07
Hi there, @SunsetRunner. Thanks for stopping by in the Fitbit Community Forums and for the details provided in your post. We're to help you!
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
@Guy_ Thank you so much for your input!
