07-18-2019
06:27
14:32
07-18-2019
06:27
14:32
HELP....My Versa Lite is less than two months old. This morning my screen went from white to black. I'm trying to charge it but nothing is happening. If the battery is dead, won't it indicate it's being charged when plugged in? I've pressed the button on the side and nothing. I thought I'd restart as suggested, but there is not back button. I'm at a loss. Would you please help me?? Thank you.
Best Answer08-19-2020 11:42
08-19-2020 11:42
I did everything you did Kelly and nothing worked. It was still tracking but the screen was blank. I did get in touch with Fitbit help online and the only other suggestions they gave me was to rub the prongs on back of versa with rubbing alcohol and the Fitbit charger and try to charge for a bit, but that did not work either. My versa light was purchased last summer but it must have been just over a year old so they would not replace it, they did offer a discount 35% off a new one. 😞
Alison
Best Answer08-19-2020 12:33
08-19-2020 12:33
Best Answer08-19-2020 14:18
08-19-2020 14:18
08-20-2020 04:50
08-20-2020 04:50
Best Answer08-21-2020 09:22
08-21-2020 09:22
Same thing happened to my fitbit versa lite. I tried all those suggestions from the forum but nothing helped. Screen would just turn dark gray when on and then turn black. It still syncs to the phone and tracks activities but no screen display. Since this seems to be happening to a lot of people, maybe there is something wrong with actual display screen (hardware defect) or something. I also noticed that the screen was a little laggy after the recent update. Hope they find out soon since I really like my fitbit.
Best Answer09-21-2020 04:24
09-21-2020 04:24
My Fitbit versa lite has had a blank screen today, took it off charge this morning and did realise it wasn’t working until I got to the gym. It’s also not syncing, and won’t update.
Blue tooth is showing not connected. I’ve googled and tried everything I can find.
help the side button in for 12 seconds let go for 2 seconds and held again for another 12
but it’s doing nothing.
the light on the back (that sits on your skin) isn’t flashing either. Has it just died??
Best Answer09-21-2020 04:34
09-21-2020 04:34
When my screen went blank it still tracked my steps and vibrated for notifications. And the lights on the inside still lit up. So maybe yours had a different issue which is HOPEFULLY fixable or possibly just wasn't connected to the charger properly and the battery died.
Best Answer09-27-2020 06:12
09-27-2020 06:12
Same issue
Best Answer09-27-2020 06:13
09-27-2020 06:13
What did they do
Best Answer09-28-2020 09:57
09-28-2020 09:57
Best Answer10-07-2020 09:12
10-07-2020 09:12
I'm not able to follow any of these steps since my versa lite screen is blank. I need to have it on before I can change the clock face or do anything else.
Best Answer01-25-2021 15:47
01-25-2021 15:47
I am having this exact same issue. I decided to ‘remove device’ in an attempt to set it up again, but now it’s asking me to enter the number on the fitbit, but the screen is still blank and I can’t see the number to pair it! The device is still working and it’s been ‘found’ but I can’t see a thing...
01-26-2021 03:18
01-26-2021 03:18
Best Answer04-16-2021 12:11
04-16-2021 12:11
Thank you for this answer. By holding down the side button on my Versa lite for 10 seconds I was able to get it to restart. Now my watch face is back and it is sincing fine. 🤩👍🏼
Best Answer06-02-2021 03:34
06-02-2021 03:34
You are lucky but more then 90 percent ppl are facing issues with lite version and nothing is working out. My watch is not turning on and custimer service guys asked to me hold button for 10 second nothing happened then they asked to rub alcohol on golden points and on charging lins still not working. I have hardly used my watch. its so disappointing. can any1 help plz
Best Answer08-20-2022 06:51
08-20-2022 06:51
I’m the same black screen comes on when in charger as soon as I take off it goes black nightmare Fitbit won’t replace
Best Answer04-28-2023 05:58
04-28-2023 05:58
I am having the same problem and I uninstalled and reinstalled and now I have most everything back except the stats. They will not show up no matter what I
