04-17-2019 13:19
04-17-2019 13:19
New to me Versa....
Factory Reset
New App on iOS, android and Windows 10.
All find the watch
All generate a four digit code
And when entered.....
On iOS - "something went wrong"
Android goes back to account page
Windows 10 " trouble connecting to fitbit.com
Any advice.over and above the generic on here which I have done?
Thanks
Steve
04-17-2019 14:59
04-17-2019 14:59
Hi, first of all: can you explain to me why you did a Factory Reset on a new Versa? Or an I understanding you wrong about this? I assume that the most important one is to setup your Versa with your phone. Which phone are you using? If we do not know that, we're not able to help you the best way possible.
Best Answer04-18-2019 06:42
04-18-2019 06:42
Best Answer04-18-2019 06:49
04-18-2019 06:49
Hi, yes. Maybe this workaround can help you setup your Versa: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... good luck!!
