08-01-2020
12:52
19:40
RicardoFitbit
08-01-2020
12:52
19:40
RicardoFitbit
Button stuck tho tapping on screen eventually comes up if you accidentally go to say timer you cannot get out of it takes a few minutes to go back to clock face
01-14-2022 12:10
01-14-2022 12:10
Best Answer05-07-2022 19:19
05-07-2022 19:19
Hi Ricardo, I am having the same problem. My screen is stuck on the set up wallet screen, I've tried all the suggestions, but my button on the side is stuck, and i can't push it in. I've cleaned it as suggested but nothing. Can you help!
Thank you!
Sandy
Best Answer09-16-2022 04:06
09-16-2022 04:06
Having the same problem as most but its the left button (the single button by itself) have tried all options and nothing is working. Any other suggestions?
04-23-2023 21:11
04-23-2023 21:11
I have a fitbit versa (first model) & did have two stuck buttons. I have now fixed these & buttons work successfully. Here is the fix:
Select a 0.004" (4 thousandth of an inch) feeler gauge. Spray contact cleaner over the button while sliding the feeler gauge up & down each side of the button. The gauge is a tightish fit & slides in each side. Repeat this several times while pulling (using pliers gently) & pushing the buttom. Now your Fitbit is like new. Cheers.
