08-01-2018
13:36
21:07
DavideFitbit
08-01-2018
13:36
21:07
DavideFitbit
Versa does not sync consistently. Activate Bluetooth in multiple ways.. Did a factory reset on Android and Versa. No help.
Moderator edit: format
08-01-2018 17:04
08-01-2018 17:04
@Kfcrowe, try turning off all of your Bluetooth connections and only use your versa connection. See if this would make any difference. I think if you have to many active connections your Bluetooth may go a little haywire.
Best Answer08-01-2018 19:51
08-01-2018 19:51
Tried this when I did a factory reboot on my phone. Didn't make a difference,
Best Answer08-01-2018 20:37
08-01-2018 20:37
I am having the same issue with my new versa as well.
Best Answer08-01-2018 21:56
08-01-2018 21:56
@Kfcrowe, I would call customer support.
Best Answer08-02-2018 07:52
08-02-2018 07:52
Best Answer08-02-2018 07:53
08-02-2018 07:53
