06-17-2018
06:27
05:01
MarcoGFitbit
06-17-2018
06:27
05:01
MarcoGFitbit
Fitbit what happening with your syncing !
I have to restart my phone , restart my watch and in the end it doesn't work .
Anyone planning to purchase the watch pls don't they have syncing issues .
The watch is good but the connection for Bluetooth and notification sucks big time.
01-14-2020 00:25
01-14-2020 00:25
02-08-2020 00:46
02-08-2020 00:46
yes but you seem to have to keep redoing this over an over - On my iPhone 5s there is only one other bluetooth device connected, my car and only when I'm in it. On the Fitbit phone app, All-Day Sync is on, but the only time it will sync with the fitbit is if both devices are on charge and sitting side by side. This means my watch time is nearly always wrong and it's not getting any notifications from the phone - pretty useless except for counting steps. I open the Fitbit app on my phone, with the watch on the wrist of the hand I am holding it with, and it sits there saying it is "looking" for several minutes before just stopping. "Sync Now" is greyed out not an option, but even if it were, I shoudln't have to keep manually doing that - I certainly didn't for the first 10 months I had the watch.
02-10-2020 16:24
02-10-2020 16:24
My Versa 2 wont sync. It was working until yesterday am. I turned off and on wi-fi, bluetooth, restarted my phone, force stopped the app, deleted the app and re-installed it, and I even deleted my previous fitbit that died in January. All software is up to date on my phone and the Versa 2 as well as the app itself. The app just cannot fund my fitbit. I have had the Versa for less than 2 months. It counts steps but isnt getting notifications and I cannot update my steps in the app so I am not competing in my challenges. So frustrating to have spent the money on something that doesnt work. Ugh. 😡😡😡
02-10-2020 16:42
02-10-2020 16:42
02-10-2020 17:04
02-10-2020 17:04
I just purchased the Versa2 and It won't sync to save my life. Can't put music on it. It just crashes, and that's it.
I'm well versed in computers, but not so much with iTunes. I understand what is happening. Its attempting to access iTunes, but crashes for some reason.
02-11-2020 07:02
02-11-2020 07:02
02-11-2020 07:42
02-11-2020 07:42
02-13-2020 07:01
02-13-2020 07:01
I've tried all of this 3 times, still not syncing - any other advice?
02-13-2020 07:19
02-13-2020 07:19
02-13-2020 16:57
02-13-2020 16:57
I recently had to do a factory reset on my versa, delete my Fitbit account and reinstall them together. I am really frustrated with this problem and have not found a reasonable solution.
02-14-2020 01:21
02-14-2020 01:21
02-14-2020 02:48
02-14-2020 02:48
02-14-2020 03:43 - edited 02-14-2020 03:46
My phone is on the supported devices list (LG G6) and at first, aprox first 6 months of 2019, it worked perfectly. Then i had do start syncing it manually sometimes and most of the times notifications didn't work. Well now this is a total gamble. Today i've tried 3 hours already. And no, uninstalling is not an option for me. This is unreal. FIX IT, Fitbit!
02-14-2020 05:47
02-14-2020 05:47
mine has been hard to sync for over a month! trying to sync it as I type ,tried shutting it down and re starting etc. for a while it would only sync once a day in the morning ,now it won' do that GRRRRRR
02-14-2020 05:52
02-14-2020 05:52
I down loaded the app on my PC then hooked the FB up using charging cable it works and also synced the phone .
02-14-2020 06:30
02-14-2020 06:30
02-14-2020 06:37
02-14-2020 06:37
02-14-2020 06:54
02-14-2020 06:54
Unfortunately if your phone is on the list is doesn't work either. That is the worst excuse ever.
02-14-2020 06:58
02-14-2020 06:58
02-14-2020 21:17
02-14-2020 21:17
I've got to agree. I worked with support twice and it's been months since I have been able to get my Versa to sync. I was told it was a known issue with the most recent android os and that it would be resolved eventually. Still not resolved and how will it be resolved if my device won't connect to sync/update?
🙄 I paid over 150 dollars for less than a year of use and now I just have a watch that won't even tell time correctly.
