07-17-2019
16:23
13:57
AlvaroFitbit
07-17-2019
16:23
13:57
AlvaroFitbit
So i've had the Fitbit Versa for over a year now. Purchased May 18, went on holiday June 18 and it stopped syncing. Got back off holiday to find my phone was no longer compatible with the Versa.
Got a new phone as contract was up the Huawei P20 Pro, again not compatible despite being one of the highest selling phones but I can agree that's my fault. So my Versa is now sat on a shelf for about 5 months being useless.
Finally my phone is compatible with the Versa, or so it should be. I set it up and it worked fine for 3 days, then I had to remove and reconnect it, this didn't work so had to factory reset. Then I had the same issue a week later. The notifications have never worked, the sync is temperamental and I have to do a factory reset every few days. Now it synced 11th of July, won't sync since. Done the factory reset and the same issue. What I have is essentially a digital watch that I can use as a contactless card. Pointless tracking any data because it's lost.
Whenever I contact support they're always helpful and resolve the issue but the issue comes back in a couple of days making everything completely pointless
07-23-2019
14:00
07:29
07-23-2019
14:00
07:29
@Ryanatix, welcome to the Fitbit Community! It's great to have you here! Sorry for the delay in my reply.
Let me help you syncing your Versa with your phone and thank you for troubleshooting this issue. I suggest you refresh the link between your phone and your Versa by doing the following:
Let me know how it goes.
07-23-2019 14:28
07-23-2019 14:28
I am having the very same issue, though tonight it's hit a new barrier in that unpairing the device and trying to reconnect it to the app won't even work. I've tried absolutely everything suggested on these forums over the past few weeks, to no avail (or temporary fixes). I'm at my wit's end, and am probably going to ask the retailer to authorise a refund as it is less than 2 months old.
