07-28-2019
14:30
07:19
AlvaroFitbit
07-28-2019
14:30
07:19
AlvaroFitbit
My versa is less than 65 days used and suddenly it wont turn on! I have bought a new charger, held all 3 buttons down for almost 1 minute, and NOTHING! I am so disappointed 😕 anyone have any super helpful hints??
07-28-2019
21:21
07:19
AlvaroFitbit
07-28-2019
21:21
07:19
AlvaroFitbit
Hi @Mamabearj76 I have flagged a moderator to come and help you
Helen | Western Australia
07:21
08:34
07-29-2019
07:21
08:34
@Mamabearj76, welcome! It's great to see you around!
Let me help you with your Versa not turning on and thank you for troubleshooting this issue. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
@NellyG thank you for your help here.
Let me know how it goes.
