07-18-2019
16:49
14:02
AlvaroFitbit
07-18-2019
16:49
14:02
AlvaroFitbit
07-23-2019
14:04
07:28
07-23-2019
14:04
07:28
@martagomes66, welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my response.
Let me help you with your unresponsive Versa and thank you for troubleshooting this issue. You haven't mentioned if your Versa is charging or if you tried a restart. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.You can also find additional suggestions here.
Let me know how it goes.
Best Answer07-23-2019 15:44
07-23-2019 15:44
