12-16-2018
11:08
17:10
EdsonFitbit
12-16-2018
11:08
17:10
EdsonFitbit
After I have started the Run exercise the Fitbit repeatedly pauses the program. Is there a way to correct this?
Moderator edit: added label
12-16-2018 11:26
12-16-2018 11:26
Hi, would you be so kind as to tell us when the Versa pauses during running. In some cases it's normal that the Versa pauses.
Best Answer12-16-2018 11:29
12-16-2018 11:29
Best Answer12-16-2018 11:39
12-16-2018 11:39
Are you moving than or not?
Best Answer12-16-2018 11:52
12-16-2018 11:52
Best Answer12-16-2018 11:58
12-16-2018 11:58
Maybe this might be the problem. You're indeed running but your position/location stays the same. Please check if this also happens when you're running outdoors for, let's say, ten minutes. Mind that the Versa pauses when you have to stop, f.i. for a traffic light. Hope this helps, keep me posted.
